High-Speed Digitizers
Why Isn't the 5761 Trigger Level Scaled According to Coupling
The LabVIEW 2013 FlexRIO examples for the 5761 scale the ADC input counts according to "Coupling" (2 for AC coupled and 1.23 for DC coupled):
Yet the trigger level is not scaled according to coupling:
The Scale Data sub VI scales "2" to unity.  It seems the Volts To Codes sub VI, and the example, are compatible with the AC coupled module only.
Why aren't the counts scaled the same way?
Steve K
(4,030 Views)
Looks like an oversight. You would want to use the same scaling for both.
(4,027 Views)
