NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
maggotsBrain
Re: Where to download instruments drivers?
By the way, what advantages confers a self-made program on LabView over the Ni-Scope Soft Front Panel?
Member
Jason_L1
Maggots,
The Soft Front Panel just allows you to do quick measurements with basic functionality:
  • Load/store waveforms
  • Load/store device-specific configurations
  • Make scalar measurements
  • Use NI-SCOPE utilities such as Auto-Setup and Self-Calibration
When you use the NI Scope with LabVIEW, you will be able to pull the waveforms into LabVIEW to process them in software. Programming with LabVIEW also allows you to do multiple device synchronization, handle continuous acquisitions, among other things. I would check out the examples folder once you have everything running. Navigate to Start»All Programs»National Instruments»NI-SCOPE»Examples to find them.
Jason L.
Member
maggotsBrain
I have reinstalled the ni-scope driver and now I have access to the same menu of that of your screenshot. However, I am afraid that the thing won't work properly as my hardware (a PCI 5105) was already installed in the computer when I reinstalled the software. This could be a problem as it is clearly said to install software before hardware in the manual.
Do I have to take the PCI back out and then in again?
Member
maggotsBrain
Although the problem I mentionned, LV seems to reckognize my PCI-5105 because I can put itd MAX asigned name into the input name of the initialize function.
Member
Jason_L1
Maggots,
I don't believe it matters too much if your card is inserted at the time of driver installation, it is just a good safety precaution to do so. I would just give your computer a restart after installing, and you should be good to go. The fact that your MAX and LV can detect the card is a good sign.
Jason L.
Member
maggotsBrain
I guess it's going to be all right too.
Thank you for your help and your concern.:smileyhappy:
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
