05-18-2012 01:36 PM
I need the instrument driver described in this link:
but I can't find the download button. Any help?
Solved! Go to Solution.
05-18-2012 03:07 PM
Hi Maggots,
I believe these are just the regular NI Scope drivers that we offer for free on our website. You can find them at ni.com/drivers. The latest such driver is actually 3.8.7 which can be found here: http://joule.ni.com/nidu/cds/view/p/id/2681/lang/en . Did you specifically need version 3.6?
Jason L.
05-19-2012 01:52 PM
All right, I installed it but then shouldn't I have access to ni-scope functions in LabView? (Express > Input > Instruments Driver) I think I should have at least an initialize function. I do not undersand.
05-21-2012 08:28 AM
maggotsBrain,
You may have downloaded the incorrect version of NI SCOPE for your version of LabVIEW. I would double check the compatibility between the two. The NI Scope drivers should be in that location, but it is also in Measurement I/O -> NI - SCOPE. You may have to repair or reinstall the drivers.
Jason L.
05-21-2012 01:08 PM
I can't be using an inappropriate version of NI-SCOPE as it was sent on a CD with my device.
I'll try the path you recommend tomorrow.
05-21-2012 01:09 PM
What is surprising with this is that the NI-SCOPE soft front panel seems to work well.
05-21-2012 01:34 PM
Hi Maggots
What version of LabVIEW are you using and what version of NI Scope is bundled on that CD?
Jason L.
05-21-2012 01:45 PM
LV:2010 and NI-SCOPE: 3.8.7
05-21-2012 05:07 PM
Hi maggotsBrain,
I have the same thing installed, and this is what I see. Can you confirm you do not see this?
-Andrew
05-21-2012 05:46 PM
Lucky you! I'll try to reinstall the driver.
