Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
01-03-2013 10:11 AM
Completely right! Sorry for the mistake. I haven't started all the "work engine" since the new year eve 🙂
Thanks you very much again for your help.
Best regards!
03-05-2014 09:23 PM
Hi joonasmikkola,
Sorry about replying an older post. But, can you tell how you solved the issue? Were you able to read the data using the same command or did you have to use more parameters?
Many thanks
Thanks!
We'll be in touch soon!
