High-Speed Digitizers
Question about PXI-5105 with external sample clock
I am now using PXI-5105 to get data.
My question is about using external sample clock (about 30MHz).
Is it necessary to set external sample rate? Can 5105 detect sample clock frequency automatically?
The exact external clock frequency is unknown in my case.
Thanks.
(5,491 Views)
Hi Minmie,
The set sample rate is used to determine the xIncrement within the cluster (or dt of waveform) acquired. You do not need to set the exact sample clock value in order to acquire data. 5105 does not detect the frequency.
Yusuke Minami
Applications Engineer, NI Japan
日本ナショナルインスツルメンツ株式会社 技術部 巳波裕介
Yusuke Minami, Applications Engineering, National Instruments Japan
技術サポートウェブページ: http://www.ni.com/support/ja
お問い合わせフリーダイヤル: 0120-527196
(5,456 Views)
