04-24-2014 11:15 AM
I am unable to get my PXI-5620 to do anything besides appear in NI MAX and pass a self test.
I have tried running several NI-SCOPE example VIs, and the NI-SCOPE Signal Express VI on the target "TransOsc" but both fail to find the 5620 module (It does not appear on the I/O pull down menu even after selecting "refresh").
Attached below is a screen shot with the following items displayed;
04-24-2014 02:40 PM
What OS are you using? Or more specifically, what bitness? I do not believe the 5620 supports any 64 bit OS.
04-24-2014 03:43 PM
My computer is running windows 7 (64 bit). I am running labview 2013 SP1 (32 bit).
04-24-2014 03:45 PM
Looking in the NI-Scope Readme, the PXI-5620 is not supported on Windows Vista/7/8 64-Bit.
04-24-2014 05:53 PM
After consulting the readme for NI-SCOPE 4.1 I found that
"The run-time installer does not support the NI 5102, NI 5112, NI 5620, or NI 5621"
I am running RT 13.0 on the target. Is this why I cant interface with the module?
04-24-2014 05:54 PM
Why does the module care about the operating system of the host computer? Shouldnt it only care about the OS of the target (RT 13.0)?
04-24-2014 06:56 PM
You are right, only the OS of the target matters. I missed in the screen shot that it was remote.
As you found in the NI-Scope Readme, the 5620 is not supported on LabVIEW RT.
04-24-2014 08:38 PM
So how do people normally interface with this device?
I suppose one option is to partition the hard drive of the target and install a compatible version of windows?
04-29-2014 02:48 PM
If you have a chassis with a RT controller, you wont be able to run VIs on the host side that can find device names in that chassis. You have to make the VI part of a project and deploy it on the RT controller.
