NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
JCC_(SK)
PXI-5152 MIG hardware error
Scope card PXI-5152 Serial Number: 0xE95906
Chassis: PXI-1045
Software: NI-SCOPE 3.7, LabVIEW 8.5, TestStand 4.0.1
Scope measurements return sometimes this error:
Error Message: niScope Multi Read WDT.vi:1Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support.
Component Name: nihsdrk
File Name: p:\Measurements\DHV\DIDE\export\2.5\2.5.0f2\includes\nidide\timing\tSharedTimingChip.cpp
Line Number: 1491
Status Code: -238801
Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support. [Error Code: -238801]
Member
JCC_(SK)
Re: PXI-5152 MIG hardware error
Do you know what wrong is with this Scope card?
What we should do?
Member
Stephen C
Hi JCC (SK),
Has the hardware ever ran successfully?
Can you confirm if you are using LabVIEW 8.5 or 8.5.1 as the scope 3.6 driver doesn't explicitly mention supporting 8.5 in the readme file. It may be worth trying to use the scope 3.4 driver to see if it resolves the problem.
If this doesn't help, the problem will most probably lie in the hardware, you should contact your local National Instruments branch to find some further troubleshooting steps and information about repair or replacement options. In the UK the contact number is 01635-523-545.
Stephen C
Member
JCC_(SK)
Hi Stephen
You are right NI-Scope version is not correct.
There is LabVIEW 8.5 installed in the system and originally NI-Scope version 3.4.1f6 was installed.
Customer installed NI-Scope 3.7 to the system. I don't know why.
Could be this higher version of NI-Scope source of my problem?
Looking forward to your answer
 Peter
Member
Stephen C
Hi Peter,
I had a look through our internal resources and the error code does not appear often enough for me to be able to single out the cause of the problem.
I suspect that it may be a hardware fault but I would certainly check the driver as a first troubleshooting stage.
Stephen C
Member
JCC_(SK)
Hi Stephen
Dose it mean that I should downgrade to NI-Scope drivers which support LabVIEW 8.5?
Member
Stephen C
Hi Peter,
Yes, I would try to downgrade to NI Scope 3.4. This one is definitely supported by LabVIEW 8.5.
Stephen C
Member
TimmTheEnchanter
[ Edited ]
Hi Peter,
Could you try to run the following three from MAX (Measurement & Automation Explorer)?
1. Device Reset
2. Self-Test
3. Self-Calibration
If you see any errors on this, please let us know what those are.
If all of these seem to work correctly (without errors) could you please describe what your code is doing?  Are you able to reduce the code down into something very simple, which reproduces the issue, in LabVIEW?  It would be ideal if we could see a shipping example for NI-SCOPE with a particular configuration which reproduces the issue.
Could you also describe your system setup?  Are you using a PXI or PXIe controller with the PXI-5152?  Or are you using a MXI controller to a desktop computer?
Which chassis are you using it in? (1075, 1065, 1045, etc.)  Which slot?
-Andrew
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
