High-Speed Digitizers
Is there any example of niScope Send Software Trigger Edge
That's the sub VI:
In my case, PXI-5105 and 6368 are used for sync acquisition. Data pre_trig_event and post_trig_event are needed for analysing which analogue channel has the abnormal changing. The trig source is not  unique,which include several analogue channels. So I prefer to use software to process many channel data to find the abnormal changing and then send out a trig signal, which means a trig signal to the PFI or the PXI_Trig. I think the noScope Send Software Trigger Edge works. Can you give me a example of this sub VI?
(6,308 Views)
Accepted by topic author zsj
I've attached an example that uses software triggering to trigger an acquisition.  The code demonstrates how to use the "niScope Send Software Trigger.vi".
From the description of your application, it sounds like you want to acquire data continously and do some processing on it in LabVIEW to determine when to send the software trigger.  This can also be done, and I would reccomend starting with one of our continous streaming examples, like "niScope EX Fetch Forever.vi", which can be found using the NI Example Finder under Hardware Input and Output >> Modular Instruments >> NI-SCOPE >> Continuous Acquisition
Hope this helps!
-Nathan
Systems Engineer
SISU
(6,268 Views)
I must thank you for the example. This is what I want.
(6,177 Views)
