04-29-2015 11:19 AM
So I foolishly decided to set my NI Scope to automatically launch when I insert the USB cable to my PC.
I cannot figure out how to turn this off. NI Scope did not appear in my autoplay settings in control panel.
I use Windows 7.
If you know the answer I would like to know too. Thanks.
04-30-2015 07:52 AM
I am trying to duplicate your error here on my PC so that I can assist in solving this issue. I have a couple questions when set your NI-SCOPE to automatically launch how did you do this? Looking through the NI-SCOPE documentation and help files I am not seeing a way to set this. Was it done in Windows? My second question is are you experiencing autorun or autoplay? http://windows.microsoft.com/en-us/windows-vista/whats-the-difference-between-autoplay-and-autorun A description of the difference can be found at the above link.
04-30-2015 09:13 AM
Hello, Thanks for the reply.
I believe it's Auto Run.
When I inserted the USB into my PC, I selected the NI Scope from the applications popup box windows provided, and checked the always run this application.
So now whenever I insert my USB cable, the NI Scope front panel opens by default. It's not a fault, just a nuisance but I would like to be able to turn it off.
04-30-2015 09:26 AM
I believe this is ultimatelty going to be a WIndows issue. I have found this resources that discusses disabling autorun https://support.microsoft.com/en-us/kb/967715/. Unfortunately there is little that National Instrumnets can do.
04-30-2015 10:01 AM
I understand, thanks.
Sadly, the fixit tool on the link above did not solve my problem, and the registry key location it refers does not exist in my registry.
I ran the disable auto run fixit, and NI Scope still automatically runs on start up.
Strangly, this occurs for the NI USB-5132, but not my NI USB-5133 model. The USB-5132 was the one I selected the option to auto run.
05-06-2015 09:53 AM - edited 05-06-2015 09:56 AM
You could try disabling AutoPlay completely or "Reset to Defaults" from the AutoPlay configuration window. Either of those options might be able to clear the windows AutoPlay setting.
http://windows.microsoft.com/en-us/windows/change-autoplay-settings#1TC=windows-7
Other than this, I can't think of anything else to try either.
Also, the USB-5132 and the USB-5133 have different USB protocol IDs, so with one always auto-launching, that is expected.
Nathan
05-06-2015 10:02 AM
I tried this: I did reset everything to defaults a few weeks ago. Strangely, the NI USB-5132 doesn't appear on the list of devices in Auto Play.
05-06-2015 10:26 AM
Right, I wouldn't expect the device to appear in the AutoPlay list since our driver doesn't touch the AutoPlay API at all.
I was able to reproduce the issue you have on my machine, and I was able to fix it following these steps:
1. Disconnect hardware
2. Right Click on the "NI Device Monitor" icon in the system tray
3. Select "Clear all device associations"
4. Click "Yes" in the "Are you Sure..." dialog.
Turns out the NI Device Monitor implements its own custom form of "AutoPlay" that is not connected to the Windows API at all.
I hope this helps!
Nathan
05-06-2015 10:32 AM
For documentation purposes, I also found the following related KBs:
Configuration Actions when Connecting USB Devices
and
Prevent Auto Start of Measurement & Automation Explorer or SignalExpress for USB
Please note that this seccond link shows the devices appearing the the AutoPlay Configuration screen in Windows 7, this is only true for DAQmx devices and not NI-SCOPE USB devices.
Nathan
05-06-2015 10:51 AM
That appears to have solved it. Thank you. Thats much better.
