03-05-2015 11:30 AM
Yes, when using a reference trigger, the trigger timestamp uses the trigger event at time 0. Thus all pre-trigger samples are negative, and post trigger samples are positive.
03-05-2015 11:47 PM - edited 03-05-2015 11:48 PM
Hi Nathan,
In another setup, the Dev_1 trigger both the digitizer (via TRIG connecter) and the Dev_2 at the same time. You can see the signal (received signal caused by Dev_1) is actually there. (1)
Here is the result of the current setup: (2)
If the Dev_1 only trigger the digitizer, there are no signal. (3)
From the setups (1), (2) and (3), I found out the reason is that the Dev_1 couldn't trigger the digitizer via PFI 0. Follow the help file, the PFI 0/1 are the digital trigger lines, while the trigger from my Dev_1 is analog. So it may be the problem.
I'm trying to find the solution. Please let me know of your suggestions, if you have any.
Have a good day!
John C.
03-07-2015 08:44 AM
I find out two ways to solve this problem. The first requires another board followed this topic. The second one is fabrication a mini-circuit to convert the analog trigger signal to digital signal before routed to PFI line.
Hope this help!
John C.
03-10-2015 02:42 PM
What does your trigger from dev_1 look like? In our entire discussion you depicted it as a digital pulse, so if it is not a digitial pulse, what is it?
If we have to acquire it as an analog signal, on TRIG, then it can only be a reference (stop) trigger, and we cannot implement your timing and acquisition like that.
Your solution to create a comparator circuit is a good option, and using another board to acquire the post-export-delayed-trigger signal would also work, export a signal to Device_2 and seccond_5122_board .
A third option would be to use the PXIe-5170R or PXIe-5171R, which using LabVIEW FPGA, you could acquire the data, and create a delayed signal easily, since the hardware is open for custom implementations on the PFI lines.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212657
I hope this helps,
Nathan
