High-Speed Digitizers
How do I setup HSDIO waveform using U8 array input.
How do I setup a U8 array of values as a substitute for the waveform file. The Create Named Waveform when set to Data U8 gives me an error when run. I have U8 data array going in. Anyone have an example how to do this and what setting avoids the errors.
(3,610 Views)
This should be posted in the Digital I/O Forum.
  1. What error do you get?
  2. Can you attach your VI or attach a VI snippet of the Block Diagram?
  3. What HW are you using?
(3,585 Views)
I finally found an example that worked. Putting the HSDIO VI's into my vi gave an error, but the same code in example worked fine. Still unsure why I got error, but got working.
(3,564 Views)
