03-23-2015 09:21 AM
Hello everyone,
I'm currently writing my bachelor's thesis and I need to come up with a solution on this Problem. Unfortunately I cannot go into detail about the topic but I'll try to answer all questions that you have regarding my hardware demands.
I need to measure 30 different electrical signals that are comming from pressure sensors. The impulses are expected to come at different times, which I have to measure with an accuacy of at least 0.01 ms. All this is happening in a harsh envoirement (~40° C, very dusty and generally unfit for a standard PC)
So far I've been reading the guidelines and come to the conclusion that the biggest problem I have is the amount of channels i require. I found this document here (http://www.ni.com/white-paper/14400/de/) giving advise about the high-channel-count problem. The solutions presented there seem to be an overkill (too expensive).
Other oscilloscopes like this one here (http://sine.ni.com/nips/cds/view/p/lang/de/nid/203719) obviously do not have enough channels for me.
So my questions are..
1. An accuracy of 0.01 ms means my sample rate should be at least ~10.000 S/s (1MS/s would be enough I guess)
2. is there way of getting my 30 channels other than using a PXI-based system? (laptop would be the best)
3. What kind of Oscilloscopes/Digitizers could you suggest me?
With kind regards from Germany,
Yours Luke
03-24-2015 06:22 AM
Hello Luke,
I only want to address one aspect in advance, for a specific system recommondation we used to get in contact with you in a more personal way through telefon assistance or an visit at your side. If you´re interested in, please call the sales team at the munich office or contact your personal contact directly: http://germany.ni.com/vertrieb
A normal preasuere measurement includes an integrated signal conditioning for bridge-based pressure sensors including filtering, amplification, and bridge completion. But common bridge sensor modules are sampling at rates of 25-50 kS/s/ch not 1MS/s. So, what kind of sensor types are you using? Bridge based? Load Cells? Do you have a sensor specification sheet?
Your seccond point is the harsh environment, in this case - without having checked if the therefore available modules fit to your sensor - we would switch to the NI CompactRIO Plattform.
Choose the Right Hardware to Reduce System Cost in Rugged Applications
I would recommend to give us a call, to get into the details of your application.
I am looking forward to hearing from you.
Thomas
03-24-2015 10:08 AM - edited 03-24-2015 10:09 AM
Thank you for your reply Thomas,
I've contacted the munich office and we figured out that I should first find the right sensor for my problem and only then think about the devices that are used transport, condition and process the signal.
That means I started thinking at the end.
I need to measure the exact moment of an explosion that happens in direct proximity of the sensor (Inside of a explosion-proof container). Options are optical sensors or pressure sensors (accordingly to ISO)
So far I've been looking into pressure sensors because of the rugged, dusty envoirement. I have the fear that pressure sensors might be less impacted by dust and therefore require less mainentainance.
So I came upon this bridge-based piezoresistive sensor (http://www.diribo.de/media/sensors/documents/drucksensoren/pa/passive-drucktransmitter_Datasheet-TM.... <-- german
Pressure range: 50 mbar … 1000 bar
Response time: 0.1 ms
called the producer and they said it has a sampling rate of 10kS/s
so far I am unsure about the mechanical properties and if it can withstand an explosion like the one I want to expose it to.
Please excuse my lack of knowledge, but this is not my area of expertise (happens when you agree to a topic that is rather exotic to your major). Never the less I will have to find an answer at the end, and so I am grateful for any help and/or suggestions that you might have.
Thank you for your help,
Regards from Germany,
Luke
03-24-2015 10:29 AM
Hi Luke,
a funny misunderstanding, you called my sales colleague at the office who´s also called Thomas :). I forwarded him your sensor data and he will call you tomorrow.
Best regards
Thomas
03-24-2015 10:48 AM
Hello Thomas,
It's rather a coincidence than a misunderstanding, I suppose 🙂
Luke
