06-01-2012 08:37 AM
Solved! Go to Solution.
06-04-2012 03:46 AM
Anyone?
06-04-2012 05:13 AM
Sorry, the attachment is failed to be uploaded. Here it is, again.
06-04-2012 07:02 AM
Hi Sonik,
in my oppinion you have to set a timing in your while loop which should not be smaller then 1/freq.
Look at the screensot i attatched.
Regards
Matijas
06-04-2012 08:01 AM
Thanks for your concern.
But it does not solve the problem.
06-04-2012 08:56 AM
Ok, I have found the solution. I have to reduce the number of samples per channel. 1MS x 8 channels + overhead is more than the onboard memory, which is just 16MB.
Thanks for helping me.
06-04-2012 09:52 AM
Thank you for informing me that you found the solution.
