NI Home
Cart Cart | Help
You are here:
Reply
Member
Penny
Accepted Solution
5132: "The format of the string is not supported"
I am trying to stream both channels of my new USB 5132 to disk simultaneously, using the C# example "Scope: Stream To Disk".  I have entered "0:1" (without quotes) in the Channel Name box.  The result is the error "The format of the string is not supported".  Is there some other syntax or example that will allow me to stream both channels of the 5132 to disk?
Penny
Member
TimmTheEnchanter
Re: 5132: "The format of the string is not supported"
[ Edited ]
Hi Penny,
Channel String Syntax
If you try an empty string or a comma separated string (as in "0,1") do you still see that error?
Which version of NI-SCOPE are you using?  You can find this by looking in Measurement & Automation Explorer under Software.
Also, I'd be interested to know if you have any other devices (besides the 5132) which show the same behavior.
-Andrew
Member
Penny
Hi Andrew,
Thanks!  "0,1" and/or "1,0" seems to work fine - both channels are streaming into and out of the file now.  I also did put in an empty string and got the error "channelName == String.Empty".  I am using NI-Scope 3.8.1 .
Penny
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
