NI Home
Cart Cart | Help
You are here:
HiQ
Reply
Member
Rfils
how to launch an other application (like notepad) in a different window by using an ActiveX control in HiQ?
I am using HiQ and I would like to use a Control ActiveX to launch an other application like Notepad in a different window.
Could you help me?
rfils@yahoo.com
Active Participant
JeanPierre
Re: how to launch an other application (like notepad) in a different window by using an ActiveX control in HiQ?
Take a look at the help for the CreateInterface function. Notepad.exe doesn't have an ActiveX so you have to start it with a command line shell. I don't recall for the moment the function in HiQ that allows that.
LabVIEW, C'est LabVIEW
Member
Rfils
First, I built an ActiveX Control in Visual Basic:
Private Sub cmd_start_Click(Index As Integer)
Dim RetVal
RetVal = Shell("NOTEPAD.exe", 1) ' Run Notepad.
End Sub
Then, I inserted this OCX file in my HiQ notebook and I was able to load Notepad application with a single click.
Eureka!
Rodeney Fils
Member
Crickett
Thanks for the instructions.
It looks to me that this only launches notepad.
Is there a way to embed this so it looks like it is part of the LV / ActiveX app?
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
