Hardware Developers Community - NI sbRIO & SOM
SoM factory configuration
What is the NI-SoM factory setup?
Especially with reference to ethernet 0 port.
Thank you,
AL3
(4,661 Views)
AL3,
The default configuration for Ethernet Adapter eth0 is DHCP or Link Local. This means the SOM will attempt to establish a DHCP network connection. If the SOM cannot initiate a DHCP connection, it will connect to the network with a link-local IP address. Is this what you meant by factory setup or is there something else I can help answer?
Bryan
(4,019 Views)
