Hardware Developers Community - NI sbRIO & SOM
Feasible? 9651 (SOM) - EtherCAT and SoftMotion
I know that the SOM can run the EtherCAT using the second port and thus enable it to connect to 3rd party EtherCAT hardware.
What I am wonder is if I can leverage SoftMotion on the 9651 with Elmo SDI plug-ins for running the Elmo Gold drives over the EtherCAT.  I could find no mention of SoftMotion running on a SOM.
Thank you.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(3,982 Views)
Accepted by topic author RVallieu
Yes, you should be able to as long as you use the secondary Ethernet port and follow our best practices guidelines for the Ethernet circuitry.
(3,972 Views)
