02-09-2015 11:55 PM
<This is a duplicate of this question, but I someone requested that I also post here: http://forums.ni.com/t5/LabVIEW/Corrupt-globals-vi-using-git/m-p/3087628#M882698>
I should also note that I am not using any git plug-ins for LabVIEW -- just plain old git (which may not be the smartest thing in the world...)
I am developing a LabVIEW program using v2013 and I keep it under version control with git.
Recently, I tried to push a few changes to the repository from a computer with LabVIEW 2014. I added a new vi and changed the globals file.
Unfortunately, there is something corrupt about the globals file. Here is the behavior I observe:
- When I copy and paste a reference to a global in a vi that uses it, I cannot wire it to anything or change the global variable name (the gray selection menu does not appear). Double clicking does not take me to the globals.vi file.
- Any globals that were already in a vi behave as before: they are wired and you can select which global variable from the menu. Double clicking will open globals.vi file.
- When I try to create another global in the globals vi file using copy + paste, it is not editable (either the value or the name)
Here's what I've tried, with no change in behavior:
- reverting my changes to a previous commit (before I merged with the newer version of labview)
- recloning repository
- copying a version of globals.vi that was saved for v2013 (on the v2014 computer) and replacing the globals.vi file on the v2013 computer.
What should I try? I'd love to not have to rebuild the globals file from nearly scratch. Are there particular temporary files that need to be removed for globals to start to work again?
Kristen
