GDS(Goop Development Suite)
GOOP Suite: questions before starting to use
Dear NI/GDS Community,
I'm just starting with GOOP Suite, and let me, please, ask you couple questions, on which I haven't found answer yet...
1. While installing GOOP from VIPM, it recompiles all VIs, from vi.lib\addons folder. It takes a tramendeous amount of time... Why it is needed, and what will be the consequences, please, if I'll discard this recompile (I understand, that it is needed for GOOP VIs, but I don't understand, why it is needed for other VIs).
2. Help files are not opened. I can find htm files on harddrive and open them, but via normal open, it is written, that file is not found. I thought, that they are blocked b/c downloaded from internet (what sometimes happens with chtm files), but no...
3. Are there some video tutorials of how and when to use this toolkit? B/c those links from LAVA forum, what were placed here also, are not valid anymore; and on youtube there is no video of how to use it exactly.
Thanks a lot in advance,
sincerely, kosist90.
(7,818 Views)
  1. To get around to re-compile problem, why not try the OpenGDS version, it’s the same code (plus some bug fixes and some extra features).
    It produces exactly the same code/classes/methods, but the advantage is that there is a pre-compiled version for all LV versions.
    Download it from: http://opengds.github.io/
  2. If you install the OpenGDS version the help files are located here: \LabVIEW XXXX\resource\Framework\Providers\Open_GDS\HelpFiles
  3. The videos could be found here: https://forums.ni.com/t5/GDS-Goop-Development-Suite/Videos/m-p/3390729#90310
(7,523 Views)
Great, thank you very much!
(7,523 Views)
Because the first thing you read on the OpenGDS page is a recommendation to open NI's version:
" I recommend you to use NI’s version to start with: https://www.ni.com/en/support/downloads/tools-network/download.goop-development-suite.html "
It is a bit confusing...
(5,330 Views)
