05-30-2016 05:40 AM
Hello Forum
After updating the VI Icon in a VILIB (Project->Goop->Edit Icon...) the Vi description is lost! This happens to me with the latest OpenGDS and NIGoop as well.
I have crosschecked it with LV2012 without any problems. Is there a known problem or is there something wrong with my installation?
Thanks in advance
05-31-2016 10:12 PM
Thanks not good 😞
I can't understand how this could happen, but I'll have a look.
05-31-2016 10:21 PM
I did try and I can't reproduce it.
I tested it on 2014 32 bit.
If the installation is corrupt, I would think nothing would work.
How can I reproduce your steps?
Maybe post your code, maybe there is an issue with the VI.
This is the VI that gets running:
C:\Program Files\National Instruments\LabVIEW 2014\resource\Framework\Providers\Open_GDS\ClassProviders\Common\IconEditor\GDSIconEditor_CreateVIIcon.vi
You can easily debug it by swapping the case in the disable diagram structure on the BD.
06-01-2016 12:56 AM
Hello Mikael
Thanks for your quick response. Please try to reproduce this with the following link.
https://www.dropbox.com/s/5wzbqzzczw1a18d/Test.zip?dl=0
It happens to me allways if i want to update the Test.vi icon.
Project->Test.vi->Goop->EditIcon (accept)
Now the ViDescription is gone. ;-(
Ps.: If i attach the Test.vi to a Class, everything works without any problems.... (Just a hint)
