Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
NI PXI-2584 specifications.
Risolto!
Vai alla soluzione
Hi all,
I would use the NI PXI-2584 to multiplex 7 Chs to a DMM. These are the features of the channels:
150Vac 50Hz up to 40W and 320 Vdc
I need to perform measurements one channel at time, so when I have to switch from one channel to the other, the power is off. I read in the specifications that the power switching supported by this module is equal to 10 W. I would Know if its use for this application is appropriate. Thanks.
Fabio.
Rgds
Messaggio 1 di 2
4.344Visualizzazioni
Soluzione
Accettato da autore argomento SemTech
Hello Fabio,
you already took a look at the specifications so I just want to confirm you that the maximum input power is 10 W, so you might damage the board if your signal is above tha limit value.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
Messaggio 2 di 2
4.333Visualizzazioni
