in data 11-27-2008 03:19 AM
Hi all,
I would use the NI PXI-2584 to multiplex 7 Chs to a DMM. These are the features of the channels:
150Vac 50Hz up to 40W and 320 Vdc
I need to perform measurements one channel at time, so when I have to switch from one channel to the other, the power is off. I read in the specifications that the power switching supported by this module is equal to 10 W. I would Know if its use for this application is appropriate. Thanks.
Fabio.
Rgds
Risolto Andare alla soluzione.
in data 11-28-2008 07:21 AM
Hello Fabio,
you already took a look at the specifications so I just want to confirm you that the maximum input power is 10 W, so you might damage the board if your signal is above tha limit value.
