Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
DAQmx and Ubuntu
Hi
I have installed Labview 8.6 under Intrepid Ibex (8.10) Ubuntu distribution
and then I have downloaded the DAQmx driver (DAQmx801f0.iso) from the national site and saved in my computer directory
    max@skynet:~/Scrivania/Documenti/linux/DAQmx801f0$ ls -l
    totale 90748
    drwxr-xr-x 2 63005 63005     4096 2008-12-01 18:28 bin
    -rw-r--r-- 1 max   max      52388 2009-02-07 14:28 ConfigurationGuide.html
    -rw-r--r-- 1 max   max      99652 2009-02-07 14:28 INSTALL
    -rw-r--r-- 1 max   max      19588 2009-02-07 14:28 LICENSE.txt
    -rw-r--r-- 1 max   max   92551244 2009-02-07 14:28 nidaqmx-8.0.1f0.tar.gz
    -rw-r--r-- 1 max   max      14334 2009-02-07 14:28 PATENTS.txt
    -rw-r--r-- 1 max   max      33375 2009-02-07 14:28 README.txt
    drwxr-xr-x 2 63005 63005     4096 2008-12-01 18:28 rpms
    -rw-r--r-- 1 max   max      28073 2009-02-07 14:28 UNINSTALL
At beginnin I had not suppllied the RPM files and Ubuntu installed DAQmx without errors but in the in the "programming palette ----> measurament I/O" I had not found any new icones.
I have been supplied the RPM files:
    sudo apt-get install rpm
and I have re-installed the drivers
    max@skynet:~/Scrivania/Documenti/linux/DAQmx801f0$ sudo ./INSTALL
Ubuntu say me:
    Checking required install tools...
    Checking installer tool versions...
    rpm        4.4.2.3 can be used with a default installation path
    tar        1.20
    Checking dependencies...
    Warning: glibc was not found in the rpm database, but
         it appears to be installed on your system.
         This most likely means you are not using a RPM based
         Linux distribution, and need to manually populate your
         RPM database, or install with the --nodeps option.
Then I respond with:
    max@skynet:/media/cdrom$ sudo ./INSTALL --nodeps
and Ubuntu again:
    tar        1.20
    glibc      2.8.90
    Unpacking install files to /tmp/nidaqmx-8.0.1f0.install...
    Do you accept the license? [ynq] y
    LabVIEW 8.0 not detected
    Manually specify a location for LabVIEW 8.0 support files? [yN] n
    LabVIEW 8.2 not detected
    Manually specify a location for LabVIEW 8.2 support files? [yN] n
    LabVIEW 8.5 not detected
    Manually specify a location for LabVIEW 8.5 support files? [yN] n
    LabVIEW 8.6 detected in /usr/local/natinst/LabVIEW-8.6
    Install LabVIEW 8.6 support files? [Yn] y
    NI-DAQmx for Linux Installer Distribution version 8.0.1f0
    is about to be installed using rpm at /usr/local/natinst
    LabVIEW 8.0 support will be skipped.
    LabVIEW 8.2 support will be skipped.
    LabVIEW 8.5 support will be skipped.
    LabVIEW 8.6 support will be installed to /usr/local/natinst/LabVIEW-8.6
    Would you like to continue? [Yn] y
And the result is:
    Installing NI-DAQmx for Linux Installer Distribution version 8.0.1f0...
    Skipping nikali-1.9.0-f0.noarch.rpm installation, same or newer already installed.
    Skipping nipalki-2.3.0-f1.i386.rpm installation, same or newer already installed.
    Skipping nipali-2.3.0-f1.i386.rpm installation, same or newer already installed.
    Skipping labview80-rte-8.0-1.i386.rpm installation, same or newer already installed.
    Skipping ni653x-1.1.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nicdigi-1.5.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcapiexmp-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcapihelp-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcapii-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcfgi-1.4.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxef-1.4.1-f3.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxhelp-1.0.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxinfi-8.0.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxswitch-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidimi-1.9.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nidsai-1.5.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimdbgi-1.3.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimioi-1.7.2-f0.i386.rpm installation, same or newer already installed.
    Skipping nimru2i-2.4.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimxdfi-1.4.1-f1.i386.rpm installation, same or newer already installed.
    Skipping nimxpi-1.4.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimxs-4.0.1-3006.i386.rpm installation, same or newer already installed.
    Skipping niorbi-1.9.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nipxirmi-1.6.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nirpci-4.0.0-f1.i386.rpm installation, same or newer already installed.
    Skipping niscarabmm-1.2.1-f0.i386.rpm installation, same or newer already installed.
    Skipping niscxi-1.5.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nistci-1.3.3-f0.i386.rpm installation, same or newer already installed.
    Skipping nitimingi-1.5.2-f0.i386.rpm installation, same or newer already installed.
    Pre Installation ...............................
    Post Installation ...............................
    errore: Dipendenze fallite:
        labview86-core necessita di lvsupport86-daqmxexmp-1.4.3-f0.i386
        /bin/sh necessita di lvsupport86-daqmxexmp-1.4.3-f0.i386
        labview86-core necessita di lvsupport86-daqmxsupp-1.4.3-f0.i386
        /bin/sh necessita di lvsupport86-daqmxsupp-1.4.3-f0.i386
        labview86-core necessita di lvsupport86-daqmxviref-1.0.1-f0.i386
        /bin/sh necessita di lvsupport86-daqmxviref-1.0.1-f0.i386
    Error installing NI-DAQmx for Linux Installer Distribution 8.0.1f0.
    Installer is aborted.
Please Note: In a precedent installation attempt Ubuntu, while it was installing the RPM files, said me twice there was a "bad loop for" and then it aborted the installer.
Are there any people that have already coped with this problem? (and maybe solved)
Thank you very much!
Messaggio 1 di 3
6.117Visualizzazioni
scusate metto pure la versione in italiano
Salve ragazzi
ho istallato con successo sotto Intrepid (8.10) Labview 8.6
poi ho scaricato i driver del DAQmx (DAQmx801f0.iso) dal sito della national
    totale 90748
all'inizio non avevo fornito gli RPM lui istallava lo stesso senza errori -diceva lui (Ubuntu diceva di aver istallato tutto perfettamente)- ma poi nella "palette" non trovavo le nuove opzioni.
ho fornito gli RPM:
e ho reinstallato i driver
mi dice:
    tar        1.20
al che io rispondo con un:
e lui mi dice:
    tar        1.20
    glibc      2.8.90
risultato:
Ubuntu in una precedente prova mi diceva per due volte che c'erano dei "bad loop for"e mi abortiva l'istallazione.
qualcuno ha già affrontato (e magari risolto) questo problema?
Messaggio 2 di 3
6.113Visualizzazioni
Ciao,
come forse già saprai, non esiste supporto ufficiale da parte di National Instruments per la distribuzione Ubuntu.
La cosa migliore è quindi fare una ricerca all'interno dei forum: con una veloce ricerca ho ad esempio trovato questo post e quest'altro, che sembrano risolutivi.
Spero che ti siano d'aiuto!
Ciao!
Licia
Messaggio 3 di 3
6.089Visualizzazioni
