10-28-2013 01:27 PM
I have a LabView vi that communicates to a cFP device (cFP-180x) via serial (USB to serial converter actually). The development vi works just fine (communicates with cFP), however, when I create an executable it does not communicate. At first I thought it may be an issue with deploying to a separate machine, however, even when I try to run the executable on the machine that I'm doing the development work on, it does not work. I have imported the .iak file into the project, however, I have noticed that when I click "Save" in MAX, it tends to lock up. If I force it to close, and reopen, the computer will communicate with the cFP device in MAX and the development vi.
Any thoughts would be appreciated.
10-29-2013 08:45 PM
Do you get any error messages when the executable is launched? Also what version of LabVIEW and Real-Time are you using?
You can follow the troubleshooting steps in this knowledgebase to see if it helps in resolving this issue.
Regards
10-30-2013 10:07 AM
Yeah, I ran across that after posting and the second recommendation in the document worked.
