NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
robino2
cfp 2220 connection
Hello
I had been testing a cfp 2220 for a Project and I found some errors at the time to set up communication.
First, I had installed the programs but without proceed the sequence. I found the controller online but the program showed me an error in the communication (that said whether fieldpoint drivers were installed or the controllers were in safe mode).
Then, I had reinstalled everything (Labview, Labview real time, Labview deviceand drivers and for the end Labview fieldpoint in that order and using 2011 version). I could make a project but the program was stilling showed me that the controller was in safe mode (I had read that message is normal at the first time to configure in http://digital.ni.com/public.nsf/allkb/B2C128E8D364D92C86257241006D7C77?OpenDocument). I checked the dipswitch and all of them were disconnected.
After that, I tried to force a digital output to one, and at the time to put in run-state (online) the program warned me that occurred an error in the connection.
So, I entered at MAX to watch what was happen and restarted the connection. That is the moment when I couldn’t see the controller online anymore. Now I can’t create more projects because I can’t see the STB at the time to selection fieldpoint projects.
Before that occur, I could see some characteristics of the monitor system (total memory and disk space). Now I don’t and I see the connection is broken.
I have connected in crossing over the controller and the PC and used Windows 7. I already tried restarting the controller, but I didn’t obtain results. Led status haven’t blinked, It have always been in off.
I will be grateful to receive help.
Thank you.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
