NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Calvus
Re: cRIO remote panel exceeds licenses
An NI support Engineer helped me get my remote panels working.
Something isn't quite right with the 2009 distributions. I was sent a multi-user license file which I had to ftp to a directory structure on the CRIO that I had to create.
Everything is working fine now.
Member
zerosun
thanks calvus
was the same deal with me. As larger the license as better, it works fine now too.
Member
Serialdiver
I have the same problem! How can I solve it?
Member
0utlaw
Hello Serialdriver,
If you need to obtain a license file for remote front panels on your real-time target, you should contact NI via the customer service hotline (http://sine.ni.com/apps/utf8/nicc.call_me.)  It may also be worth starting a new forum thread describing the behavior you are seeing in detail (screenshots, what you are doing when this happens, has this ever worked, etc.), as this thread hasn't been updated in several years and it is unlikely that the original posters will see your comment. In either case, I would suggest contacting NI technical support for assistance troubleshooting this issue.
Tom L.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
