04-28-2010 03:31 AM
Hi @ all,
I am working with:
Problem:
I tried to run a remote panel from the RT, but when I try to open the VI with a browser (explorer or firefox), I get an Error. The Browser opens the window and loads the VI, I can see the front panel for just a second and then it jumps to with screen and tells me connection exceeds maximum number of licenses.
The Error says:
“connection exceeds maximum number of licenses”
I did the check lists which I found at the NI page:
http://digital.ni.com/public.nsf/allkb/7FEE6BCFD26
http://digital.ni.com/public.nsf/allkb/A4915E8E127
http://digital.ni.com/public.nsf/websearch/D136536
Unfortunately I checked without any positive result.
I found also a discussion in the forum, about the point that there are just more connections running on the RT, than I have licenses. I used the
View Remote Connections.vi (35 kb) |
http://forums.ni.com/ni/board/message?board.id=110
to check my open connections. It turned out that there is no open connection on the target. I am the only one working on the project anyway. I just waned to be sure.
Do you have an Idea for a Solution???
04-28-2010 06:50 AM
I have also a Generic Desktop PC with a NI PCIe-7852R. I tried the same procedure on it and it almost works correct. Instead of 5 working connections (LabVIEW 2009 Service Pack 1 (Professional Development System)) I got only one???
I don’t get it, the remote penal doesn’t work for the cRIO system (still getting the license error see above), but it does work for the Generic Desktop PC, at least for one browser connection.
04-28-2010 12:11 PM
Hi
I do know now, that the RT Remote Front Panel license doesn’t depend on the license manager. It looks like it is installed with the Real Time Module on the RT, which carries by default on Remote Front Panel license.
I found a second way (does the same) to configure the target system, but result is still the same.
Ref :
http://digital.ni.com/public.nsf/allkb/AB6C6841486
Who does when, how check for the RT license?
I tried different approaches but always with the same result.
thomas
05-01-2010 05:48 PM
I am experiencing the very same issue.
I rebooted the only PC connected to the CRIO target and when the PC came back up I rebooted the CRIO with absolutely no change in behavior.
I am running LC 2009 Pro which comes with 5 remote panel licenses and when I look at the connections to the target there are none reported.
05-03-2010 09:07 AM
Hi zerosun,
Remote Front Panels for RT targets are different than Remote Front Panels on a regular PC. RT targets will come with a license for one connection by default. Additional licenses can be purchased and activated separately. Once they have been activated, the license file is then FTPed to the RT target which allows multiple connections.
Regarding the error you are seeing, can you describe the steps you take before you see this error?
Aaron P
Applications Engineer
05-03-2010 10:04 AM
05-05-2010 12:23 AM
Hi Thomas,
Did you attempt to activate it for 8.5.1 yourself, or did the NI Applications Engineer do it for you? Did your confirmation email have the license file attached?
Aaron P
05-06-2010 10:32 AM
I can’t really say, a NI app engineer is working on it … .
05-06-2010 10:34 AM
The NI engineer sends the license files to me and I try them out …
05-10-2010 06:27 AM
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
