NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
antique
cFp-1808 IP address
I am trying to setup a cFP-1808 and in Max (5.0.0f1) am getting to the screen that needs me to put in the device IP. What is the device IP or where would I find that? I will be using LabView2011 on a XP computer.
Gerald
Member
antique
Re: cFp-1808 IP address
Here is the screen that is asking for the device IP
Trusted Enthusiast
TiTou
How do you get to that screen? Are you trying to "create" a device in MAX?
If there is no network settings issue MAX should see yout cFP, maybe this can help you.
________________________________________________________________
"Cambiar el mundo, amigo Sancho, que no es locura ni utopía. sino justicia."
Cervantes
Member
antique
The Windows firewall was blocking the 0.0.0.0 IP address for the initial setup.
Turned off the firewall and the Field point cFP-1808 popped right up turned the firewall back on it is seems to be there.
Now it has been a long time since I worked with field point but the Field Point tool pallet does not show up and the Field point does not show up in the start: Program: National Instruments menu. I will ask that question in the LabView part of the forum.
Gerald
Trusted Enthusiast
TiTou
Cool!
Did you change the font size to small on purpose? It's quite hard to read even for a young lad like me :smileysurprised:
Cervantes
Member
antique
No it was a copy and paste. I tried to make it larger and it kept making it small again. Sorry about that
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
