FieldPoint Family
cFP IP Address changes when unplugged
HI,
I have a cFP 2200 with 1 AI-110 input module, 1 AO-200 output module, and 1 RLY-423 Relay module. Every time I unplug the power to the cFP system and then plug it back in the IP address changes. I am wondering what I have to do to make the IP address remain the same when I unplug the system? Thanks for the help
(5,793 Views)
Accepted by Juke_Box_Hero
Juke_Box_Hero,
There is a dip switch on the cFP controller labeled IP RESET.  Make sure it is in the "OFF" position.
Make sure you are configuring the cFP to use a "static" IP address.
(5,792 Views)
