NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
dj143
cFP-CTR-500 32 bit Cascaded Counter
I have a cFP-CTR-500 with unused counter inputs and need to count pulses from an encoder for more than 16 bits.  (I'm currently using counter inputs 0 and 1 to measure frequency of the encoder.)  Is there a way to cascade the counters to create a 32 bit counter?  I found Cascade Counter Example.vi but am having difficulty converting the concept from FieldPoint.  (I'm not familiar with FP)   I also need the cascaded counters to be resettable.  I'm under a very tight schedule so example code to import into my project would be much appreciated.  I'm using LV 2011 but can upgrade to 2012.
DJ
Active Participant
Wayne.C
Re: cFP-CTR-500 32 bit Cascaded Counter
Simple search turned up this.  Should work for the cFP-CTR-500 as well.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
