FieldPoint Family
What's the maximum digital I/O frequency for the NI LabVIEW RIO Evaluation Kit ?
Hi!
I'm trying to analyze some sort of sine signal at the frequency of about 3 MHz. Because the analysis should be very precise and fast (about 10 samples per period), I'm needing the maximum digital I/O frequency of the NI LabVIEW RIO Evaluation Kit.
Erik
(6,510 Views)
Here is the manual for the sbRIO board specifically included with the evaluation kit. http://www.ni.com/pdf/manuals/373378c.pdf
If you have any more specific questions, please don't hesitate to ask here
Wilfred Tikamchue
(6,462 Views)
Dracyon,
Can you please clarify a couple of things: you say you are trying to acquire a sine wave that has a frequency of 3 MHz, but you are asking for the maximum DIO frequency. I believe what you need to know is the maximum analog sampling frequency. For the sbRIO-9636 (part of the evaluation kit), the maximum aggregate sampling frequency is 200 kS/s at 16 bits of resolution. At 10 samples per period, you could sample a ~20k analog signal. If you are actually looking for maximum DIO frequency, this is a bit more complicated. We have a good whitepaper explaining this.
Best,
Tannerite
(6,459 Views)
Hi , I want do a similiar system with  MyRio 1900
I need measure TTL singnal
interval 2 - 10 sample/second
1 - 10Mhz but precision 1Hz or better
and record in HD
(6,339 Views)
alissonrl,
We publish the maximum DIO frequencies for the myRIO-1900 in the . I believe you are talking about measuring the frequencies of up to a 10 MHz signal and sampling that frequency every 2-10 times a second. From the data below, you are exceeding the specifications of of the myRIO's digital lines.
Tannerite
(6,330 Views)
