03-08-2011 06:52 AM
Hello All,
I am using one cFP-2100 (controller) and two cFP-1808 (network contoller) for a project.
All the three devices have Ethernet port, so i can connect to a network switch for communicating with the Host PC.
My question is:
All the three devices have Serial Ports (RS 232) too, Can i use those ports to communicate between the three devices (1 controller and 2 Net. controllers) and use the ethernet port in the controller (2100) only for communicating with a Host PC?
If this is possible, how to do the RS 232 cabling ?
Regards
John
03-09-2011 09:34 AM
Hi bjsprem,
You can connect network modules to the controller with serial. This KB shows how to do this. Hope this helps!
--Starla T.
