09-21-2012 05:02 PM
Well, simply putting a file ini$$0.TMP in that directory (with settings like what you've described) and rebooting the target does not reproduce the problem. I tried it on a cFP-2220 with the full FieldPoint software set and add-ons installed.
I talked to Danny and he wanted to make sure you've upgraded to the latest FieldPoint driver, 6.0.11. That's the version that released last month.
If you manage to get that controller into a crashing state again when that TMP file is present, please use NI System Configuration to get an image of it that we can take a look at. If it's in safe mode at the time, set "auto restart" to false.
Dan
09-24-2012 02:00 PM
The problem is complex. Rebooting with the temp file is not enough as you also need to run an application that will try to reconfigure the device once again using the System Configuration API. There is a stage there that prevents the next restart from being succesful.
But there might be additional requirements. I believe we have a copy of all the file son the device from its crash state, I'll see if I can dig them up.
10-01-2012 06:47 AM
I have sent the files to you privately now. But the error log I sent earlier, did that give any clues?
10-16-2012 07:23 AM
No news? It would be nice to at least know if any further work on this was done. If no explanation was found, and the ball has been dropped, please tell.
11-16-2012 07:56 AM
No one seems to be following this issue, I cannot get contact with anyone who answered questions earlier, but I see that the copy of the crashing cFP-2220 did have an errlog.txt-file on it that contains error codes that seem to stem from this situation:
09/05/2012 17:26:28.453 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/05/2012 17:26:28.464 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/11/2012 10:45:50.295 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/11/2012 10:45:50.297 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/11/2012 12:15:06.946 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/11/2012 12:15:07.074 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/11/2012 14:14:07.016 0 -2147220721 000 CmxsNeoStorage::ApplyJournalAtStartup - failed to open storage, unknown exception CmxsNeoStorage::ApplyJournalAtStartup
09/12/2012 11:05:08.394 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 11:05:08.405 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 12:46:52.545 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 12:46:52.551 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 12:47:25.279 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 12:47:25.282 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 12:51:38.536 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 12:51:38.539 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 12:52:10.280 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 12:52:10.284 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 12:59:30.341 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 12:59:30.345 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 13:00:13.420 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 13:00:13.423 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 13:03:56.394 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 13:03:56.398 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 13:04:40.463 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 13:04:40.466 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 13:11:52.582 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 13:11:52.585 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 13:12:24.648 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
09/12/2012 13:12:24.651 0 0000000000 000 CmxsNeoStorage::Open2 - MXS attempted perform/restore backup/checkpoint and failed. CmxsNeoStorage::Open2
09/12/2012 13:16:23.157 0 -2147467259 000 NI Configuration Manager: Error while performing a backup
backup
I found one document here that mentions something similar:
http://digital.ni.com/public.nsf/allkb/E7D790B967B086648625756A0055A39D
But the solution given in that document is to contact NI...
11-20-2012 04:46 PM
I somehow missed the answer to the question whether this was tested with FieldPOINT 6.0.11, because it has a fix for the DHCP issue?
Could someone answer please?
DirkW
