06-09-2014 09:41 AM
I'm wondering if it is possible to use the FP-AI-112 input module to read from a digital power supply that displays flow rates. The manual for the power supply states that it has 9-Pin D-connector socket for "analog I/O functions", so I'm hoping it's possible to connect it to the FP-AI-112.
If it is possible, how would I go about connecting them? How would I determine which pins to put the FP wiring in? I have attached a small PDF with the specificiations of the power supply. Thank you very much.
06-09-2014 10:34 AM
Sure it's possible. You'll need to make your own cable to break apart the wires from the DB9. You'll also need to read the manual for the device to know what pins do what.
