02-25-2014 11:25 PM
FieldPoint: Is there a way to programmatically access (configure and read) the linear coefficients found on the Scales tab for any particular channel (e.g. MAX\My System\Data Neighborhood\FieldPoint Items\<configName>\cFP-AI-100 @1\Channel 0)?
Three special-function VIs exist in the FieldPoint\Advanced\Advanced Ethernet palette.
Configure Range.vi, Configure Atttribute.vi, and Configure deadband.vi use special extensions to the standard URL (Logos:\\FP\1AI\00) of \ConfiguredRange, \Attributes, and \DeadbandConfiguration, respectively, to programmatically configure these items (normally done in MAX or in a LabVIEW Project).
I assume there is a similar one for the scaling coefficients, and as my ESP powers have failed me lately, ... help?
Thanks, Dave
02-26-2014 02:48 PM
Changing the scale would require changes to the IAK file. Here is the forum post I am referencing:
http://forums.ni.com/t5/FieldPoint-Family/Field-point-scale/td-p/1156935
Also, you can programmatically change some of the channel attributes:
http://digital.ni.com/public.nsf/allkb/960F6F90436A1A1A86256FBA0062E463
