FieldPoint Family
FP-20xx The password you typed in was incorrect
I've just got the FP-2000. I am using LV 2010 SP1. When I try to install software on the FP I get previously mentioned condition.
Can anyone help me?
Best ragards,
Przemek
(8,915 Views)
Did you try to format it before installing the software?
Kind regards,
Ion R.
(8,895 Views)
Solved with these steps, using an NI-1454 and NI MAX:
1. Reset target device
2. Reconfigure ip
3. Update BIOS
4. MAIN STEP: Install ONLY Labview Real Time
5. Reboot device
6. Install other programs
The main problem is that you must first install the real time module before you can install others.
Good luck everyone
(6,215 Views)
I wonder how you can configure the FP-20xx with LV2010 SP1. Last LabVIEW version which supports FP-20xx is a LV 8.51
(6,203 Views)
To others who have experienced this "the password you typed was incorrect" problem, I figured out a solution that fixed a PC that was seeing this repeatedly.  For me this problem stemmed from someone changing the PC's TEMP directory to an invalid path.  Try editing your account's TEMP (and perhaps TMP) environment variables back to the default, which is "C:\users\*you*\AppData\Local\Temp"
(4,556 Views)
