01-26-2011 12:27 PM
Does anyone know of a driver for Brooks 0254 secondary electronics module to use with labview 2009 or 2010. This module is used for interfacing multiple Brooks MFC's, thank you.
01-27-2011 11:21 AM
At this time we do not have a driver for the Brooks 0254 Instruments. However, you could use the NI-VISA driver to send commands to the device through LabVIEW.
David A.
02-11-2011 04:10 AM
excuse me but there are no commands or NI-Visa applications for all 0254 brooks
questions.
For example: Which NI-Visa commands to get the pv values?
thanks
02-14-2011 10:15 AM
Each device has different commands that you can send to it using NI-VISA. I am not sure on the exact commands that you would use with this instrument to get the pv values. This link will show if you can communicate with the device in hyperterminal then you should be able to in LabVIEW and how to do it.
David A.
09-29-2011 09:07 AM
I have had the same frustration finding a driver for the Brooks 0254. Here is one I put together for simple SP send, and PV read operations for the 4 channels (not networked). I've had some trouble with Labview correctly reading the other commands outlined in the manual, and am still working on it.
I hope this helps, and if anyone out there has a more comprehensive driver, it would be appreciated.
-Andrew
03-19-2014 08:27 AM
Hey there,
there is a stand alone labview program for the brooks 0254: http://www.brooksinstrument.com/component/jdownloads/viewdownload/143-product-software/405-0254-read...
And the corresponding VIs:
http://brooksinstrument.com/component/jdownloads/viewcategory/144-labview-drivers.html
