NI Home
Cart Cart | Help
You are here:
Reply
stéphane.belche
Bad readings with CFP-RTD-124
I have a compact field point system to record t° measurements on a machine (to replace a YOKOGAWA paper recorder system)
This machine is equiped with Thermocouple and RTD sensor
TC acquisition boards are CFP-TC-120. Readings are ok
RTD acquisition boards are CFP-RTD-124. Reading are nok  : see picture attached
With the previous YOKO system readings were stable and did not show any fast variations.
If i take resistance measurements, value is also stable.
CFP-RTD-124 used is revision H (187208H-02)
In advance thanks for your support.
Regards
Stéphane
Knight of NI
RavensFan
Re: Bad readings with CFP-RTD-124
To me, it looks like just a little bit of electrical noise.  You've collected 10's to 100's of data points in a 2 second period and it looks like the results are +/- 1 degree.  (The VI isn't clear as to whether this is °C or °F)
I might be wrong, but I think the thermocouple modules have some internal filtering to eliminate noise.  I've never used the RTD module to know, but perhaps it doesn't.  Or maybe there is a setting in MAX to turn it on.
Does your temperature change so rapidly that you'd need to read numerous data points per second?  The screenshot doesn't look like it is.  One possibility would be to so some averaging across multiple data points and plot that result.
stéphane.belche
I used the shared variable engine from the dsc package. This engine is recording automatically in a database value  I do not know if it is possible to adjust the measurement period.
For sure i do not need this fast reading.
The values are recorded in a Citadel database on the PC.
The only thing possible is to adjust the
stéphane.belche
I used the shared variable engine from the dsc package. This engine is recording automatically in a database value when  I do not know if it is possible to adjust the measurement period.
stéphane.belche
I used the shared variable engine from the dsc package. This engine is recording automatically in a database value when there  I do not know if it is possible to adjust the measurement period.
stéphane.belche
I used the shared variable engine from the dsc package. This engine is recording automatically in a database value when there is a  I do not know if it is possible to adjust the measurement period.
stéphane.belche
Sorry there is something wrong , the message is now there a couple of times...
elmer85002
Hey there, I'm also having the same problem as you do.  What i did to solve it was to change the cpf-RTD-122 power supply for a DC variable lab Power supply, that corrected the issue right away.  now what im  trying to do is to find out why it won't work with the field point power supply or with another power supply.
Regards
Elmer Rodriguez
R&D Engineer
