08-10-2011 02:41 AM
I am using tags to mark some messages of interest, i.e. 'bug' or 'open_question'. Now it happens that this question gets resolved or a bug fixed and I would like to change the tag for a particular message - all I found is to delete / replace this tag for all messages. Obviously, resolving one open question does not solve all my open questions.
Is there a possibility to change a tag in a specific post only?
Wolfgang
08-10-2011 05:14 PM
Hi Wolfgang,
The process is a bit convoluted, but I believe you should be able to delete a single tag on one message by doing the following:
1. Go to the message, and click "View All" next to the tags
2. On the next screen you will see just the tags for that message, under "Tag Options", select "Manage my tags"
3. On the next screen, you should be able to individually select the tags from that particular message that you want to delete.
Let me know if that works for you.
Thanks!
Laura
08-12-2011 05:51 AM
Thanks, Laura, this approach works.
