04-08-2014 09:51 AM - edited 04-08-2014 09:52 AM
I just accepted a message as solution to my question and I received this email from NI:
Why does it say "Your answer on Discussion Forums has been accepted as a solution!"?
And who is "${solution.actor.login}" that marked my answer, that is not provided by me, as a solution?
04-23-2014 11:42 PM - edited 04-23-2014 11:42 PM
I came to post this as an issue as well, but saw you had already noted it. It's definitely a JS bug(s). The fact that the username isn't properly populated and the fact that when you mark a solution it tells you your answer was marked a solution are both incorrect.
04-25-2014 09:42 AM
Don't you hate it when some java coding weenie messes with your LabVIEW mojo?
05-08-2014 08:32 PM
JavaScript. Not Java. 😉
