11-13-2008 01:07 PM
For some reason, when I post in the forums, after my signiture it leaves 6 or 7 lines of empty spaces.
I've checked in my profile for carriage returns and there is nothing.
It should just be "Cory K" without all of the space underneath
11-13-2008 04:15 PM
It appears that the signature is embedded in a <div> tag with the height set to 180. The actual <div> tag looks like this:
<div style="width: 100%; height: 180; overflow: hidden;">
I've never used a signature, but the signature creation box is supposed to accept HTML, so maybe you can just set the HTML yourself directly.
Hmmm.... let's see what happens when I use a signature....
11-13-2008 04:18 PM
Yup, looks like that's what it defaults to, as the same thing happened when I simply put in the text "This is a signature". I got a bunch of blank space at the bottom.
I've since removed the signature, so that's why you can't see it now.
11-13-2008 04:21 PM
11-13-2008 11:36 PM
11-14-2008 09:01 AM
11-14-2008 09:37 AM
So I had to increase the space allocated for signatures a while back after an upgrade because some signatures were large and were starting to get cutoff. The extra space below signatures is more apparent in Firefox than in IE7. I have not recently revisited the issue to see what happens if I decrease the space so I'll add that to my issues to research list
Laura
Web Support & Operations
11-14-2008 02:03 PM
I'm using Google Chrome, and it is VERY apparent
