10-14-2014 06:07 AM
@Hornless.Rhino wrote:
@crossrulz wrote:
Do not mark a post as a solution to your thread until you actually have your problem solved. Many people will skip over "solved" threads. If your problem was not solved, then these people will not be helping.
I so wish I could mark that post as a solution right now 😛
Then set a good example by giving it Kudos...
10-14-2014 06:08 PM
Kudos for all.
10-17-2014 09:30 AM
Before making this thread I searched to see if one existed already. I recently found this one which has a few more tips which are forum wide.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
10-22-2014 08:37 AM
And some general LabVIEW Style tips for uploaded code:
10-31-2014 10:02 AM - edited 10-31-2014 10:04 AM
@JÞB wrote:
- Try your best to save the vi FP and BD on the PRIMARY monitor and not maximized.
hmmm.....I don't like to pull out my 40" monitor just to read the FP/BD. Try using the "Clean Up Diagram" to compress the BD view.
10-31-2014 01:17 PM
I'm not sure I would want a blanket statement like use Clean Up Diagram when posting code to the forums. I realize mostly newbies are the ones that need these rules, but I think coding style is something that is important, but not manditory for getting help on the forums. Sending users links to the style guide might be more useful than just saying to use clean up.
10-31-2014 03:25 PM
Further, Clean Up is often more likely to explode a messy diagram than to compact it.
Lynn
11-14-2014 10:00 AM
Okay finally got around to making this a community document. Posted here. I tried adding all the comments from this thread but I left a few out, and re-worded some.
