06-22-2015 10:10 AM
I entered the tag "XNode" and it got changed to "xnode".
Please fix.
Ben
Solved! Go to Solution.
06-22-2015 11:41 AM
Hi Ben,
After looking into this, it appears that if you enter duplicate tags with different capitalization, the system will alter the newer tag to be identical to the existing tag. There was an existing "xnode" tag, which is why your tag was changed. Since, most tags on the Forums are using proper capitalization (e.g. LabVIEW), I went ahead and updated the tag to be "XNode".
This change should apply to all existing instance of the tag and any future tagging, so you should see your previous tag updated.
Let me know if you see any issues!
