06-25-2016 01:47 PM - last edited on 06-27-2016 04:55 PM by LiliMcDonald
I'm a frequent "commenter" on the LabVIEW Forums. After I post a Reply, it takes about 3-5 pushes of the "back" button to get back to the main Message stream. It would be helpful if there were a "Return to Message Stream" one-click option.
06-25-2016 04:56 PM - last edited on 06-28-2016 11:00 AM by acordero0710
Bob,
1. Comments like this belong in the Feedback on NI Discussion Forums board.
2. For me, when I post a comment, it goes to the message I replied to. Does it not work like that for you?
06-26-2016 01:16 AM - last edited on 06-28-2016 11:01 AM by acordero0710
Some options:
06-27-2016 05:01 PM
Hi Bob,
At the bottom right of any topic, you will see a "message listing" link which will take you back to the board you were browsing.
06-27-2016 07:33 PM
Lili,
Thanks for pointing out that link. I had never paid any attention to it. And, like Bob, I have tried to find the best way back.
The name on the link does not "say" anything to me which would suggest that it returns to the Board. At the moment I cannot think of a better alternative.
Lynn
07-01-2016 04:34 PM
Wow! I never noticed/saw/understood that link. Indeed, I just went to the Forums to find it, didn't see it, said "Maybe I need to Post a Reply, did so, clicked "Post", but still didn't see it. I had to go find my Post (which I don't normally do) and then I saw it, a vague term "Message Listing" that, when clicked, took me back to the Message Listings.
Frankly, if I've Posted a Reply and it has been added to the Message Stream, most of the time I want to go "up one level" and return to the Message Listings. Indeed, I (personally) wouldn't object if the button were changed to "Post and Return". If you are at the Message Listings, it's a single Click to get back into the Message to which I just replied, but if I don't click the subtle, hidden "Message Listing" (for which I might need to scroll around to find), I have to click the Back button several times (and, far too often, I mistakenly click "Close" instead).
Sadly, you are dealing with Teaching an Old Dog New Tricks. Subtle doesn't work too well with habits learned over a few thousand Forum posts. Could you consider a "Post" behavior that returns you to the Message Listing, or perhaps two buttons, Post and "Post and Return"?
Do others find this makes any sense, or is it just me?
Bob Schor (and I'll look for "Message Listing" when I hit Post, and hope it will be "on screen" so I won't have to look for it ...)
07-01-2016 04:35 PM
Nope, it wasn't on screen, I had to scroll to find "Message Listing", no wonder I (and Johnsold) haven't noticed or used it ...
BS
07-01-2016 04:53 PM
If you go to My Settings > Preferences you will find an option for Show confirmation pages for posts. If you select this, then whenever you make a new post, you will see a screen with the message:
Those are your only two options. Perhaps this would be a better solution for you?
07-03-2016 04:19 PM
Wow, another option I didn't know about! I'm going to try this, since the Board is bugging me to mark something as a Solution, and I'm not at all sure which I like (Old Habits Die Hard ...).
07-03-2016 04:20 PM
Ooh, I rather like the Preference Setting change. I'm going to "live with it" a while and see if it really is the Cat's Pajamas ...
BS
