11-25-2015 01:26 AM
Somehow I thought that the forum behaviour was different before: Now, if I open an unread message on page 1 and then click on 'Message Listing', I would expect that I return to page 1 from where I started. However, if the thread, i.e., its first post, is older now I will end up at say page 3 instead. Somehow I consider this unintuitive.
For demonstration: I open the marked thread, which is found on page 1
After reading it, I click on 'Message Listing' with the result that I end up at page 3
11-25-2015 09:18 AM
Hi Wolfgang,
Thank you for reporting this. This is only happening with topics that are longer than one page. Changing the page for the topic, then clicking on Message Listing, takes you to a random page on the board.
I will report this bug to Lithium and will let you know when I have an update.
11-25-2015 10:24 AM
Lithium has confirmed that this is a bug which they are actively working on. However, there is no estimate for a potential fix at this time. I'll post again when I receive an update.
In the meantime, to return to the first page of a board, you can click on the board name in the breadcrumbs.
11-25-2015 10:49 AM
Thank you
02-12-2016 11:23 AM - edited 02-12-2016 11:24 AM
Hi Wolfgang,
This issue has now been fixed.
02-12-2016 11:27 AM
Oh wow, this is really good news
Thanks!!
