11-22-2016 03:26 PM
Christian - I was looking into that group settings and there appears to be several issues. We will need to investigate further. It should be working as expected for your account now though.
11-22-2016 05:57 PM
It is not working for me yet. I have the same issue as Christian's last picture showed.
11-22-2016 08:08 PM
All of the members of the 2016 Advanced User's Group should now be able to see the content within as expected. However, non-members will need to join to see the content as described in issue #9 listed here: Known Issues with Migration
11-23-2016 02:13 AM - edited 11-23-2016 02:16 AM
Tilee,
If you cannot see the My Groups component on the NI Community Home page, it does mean that you are not currently a member of any groups. You should be able to see the component on the left side of the homepage once you join one.
Ok, I understand now: I was only participating in the LabWindows/CVI user group that won't have any subscriber from now on, so it's correct I don't see that component.
The "Product Groups" are actually now categories and not true user groups
So what is the rationale in listing product groups into User group category?
As a general comment, after grouping all the content into a unique interface I wonder what's the usefulness of CVI user group discussion board: what is intended to be discussed there that is conceptually different from the CVI forum board or the CVI Idea Exchange board? But I suppose this should better be the argument for a brand new topic.
11-23-2016 09:52 AM
Hi RobertoBozzolo,
Our primary concern was to migrate the content as effectively as possible. As stated above, in cases where the user group contained a lot of content that would have been hard to find in the new user groups, we decided to split it into separate content types.
In the future, we may need to evaluate where there are overlaps and where things can be consolidated.
Thank you for your patience!
11-24-2016 05:05 AM
what happened to the layout of this group ???
11-24-2016 11:13 AM - edited 11-24-2016 11:14 AM
@vix wrote:what happened to the layout of this group ???
I can't even make up it's mind if it is open or closed (or both!). 😄
11-24-2016 01:33 PM
Hi vix,
I believe what your seeing is related to the width of your browser window and how the page's columns are configured to handle this. Only the post title is reducing in width and "stretching out". We will need to look at alternative ways of addressing this.
In the mean time, are you able to expand the size of your browser window? If not, zooming out should resolve the issue.
altenbach - we are looking into this issue. It appears some of the migrated groups have inherited some unusual setting when they were moved. We are investigating this and hope to resolve it as soon as possible.
11-25-2016 01:00 AM
Matt_McLaughlin ha scritto:I believe what your seeing is related to the width of your browser window and how the page's columns are configured to handle this.
on my Win7 PC the desktop is 1280 x 1024 and the browser Firefox 50.0 shows that problem.
Opening the same link with IE 11 you see what Altenbach posted
11-28-2016 06:34 PM
Update - we have resolved the issue which required you to be a member of an open group in order to see the content within.
Content within closed groups is still private and you must be an approved member to see it.
This should also resolve the issue in which you were seeing two banners - one stating the group was closed and one stating the group was open.
