07-11-2017 08:18 PM
07-12-2017 09:50 AM
Hi Jeff,
The issue seems specific to that particular image and how it was uploaded. Please let us know if you are seeing the issue in other posts.
Lili
07-12-2017 10:59 AM - edited 07-12-2017 11:01 AM
I'm seeing that same problem also.
With this post. http://forums.ni.com/t5/LabVIEW/The-distribute-object-tools-often-crashes-LabVIEW-2017/m-p/3659157#M...
Interestingly, that looks more like a Code Capture Tool snippet rather than LV built-in VI snippet.
And that brings up the question, how have people been installing the CCT in LV 2017? Recent versions of LV, I've used JKI VIPM to install the CCT. But VIPM doesn't seem to be updated yet to work with LV 2017.
07-12-2017 11:03 AM - edited 07-12-2017 11:05 AM
I had no problem installing CCT through VIPM for 2017 Did you select VIPM from the options? (For some strange reason, I think I recall that it was unchecked by default in the installer- but, don't quote me on that.)
07-12-2017 11:11 AM
Read that linked message thread for more info. Blokk seems to have found the problem with the VI snippets. The new "Image" tool on the forums seems to be breaking the snippet. When he attached the actual png file, I was able to insert that one just fine into LabVIEW.
07-12-2017 11:15 AM
Thanks Jeff. I 'll check that out. Do you mean as an option within the LabVIEW installer when I first installed LV 2017?
I don't remember seeing that in there. I had always installed VIPM based on a download from JKI. Or it updated itself when it detected updates. JKI's website still says 16.0.???? is the latest for download.
I know I needed to deselect some options when installing LV 2017. (For example, the Windows/CVI, why does it think I'd want to install that?) And I minimized the amount of extra modules I installed since I'm running low on drive space. But I just don't remember seeing anything about VIPM in there.
07-12-2017 12:28 PM
Despite the page stating it is 16, the download link is for 17. There is a thread on JKI's forums that has some confusion and has gone unanswered (along with another on LAVA at one point)
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-12-2017 12:54 PM
Honestly I just got my media last week. I upgraded a few machines via download and recall that I had to go and check a bunch of stuff I expected to automatically install, VIA, UTF, VIPM, DETT and some others. For upgrading a "Pro" key (actually an Alliance Partner Lease) the install options from the download were poor. It did check my system- and should have selected some better options based on my current configuration. I expect when I plug that 64GB USB Drive into my Laptop things will go a bit smoother.
07-12-2017 03:19 PM
Thanks Hoovahh and Jeff,
it hadn't been a high priority for me because I'm not actively developing in 2017 yet. Just using it for the sake of the forums. But of course the code capture tool is the one thing that is most helpful with supporting the forums. I'll try on of those tips in the next day or so.
07-14-2017 11:52 AM
We have escalated the issue with VI Snippets to our community provider for further investigation. We will post updates when available.
