Feedback on NI Community
Premigration Blog Posts - Missing Images
I am not sure if this is the correct place to be posting this but this issue has been going on for a while and a resolution does not seem to be coming into view.  I run the Community Blog The Daily CLAD.  Since the migration of the community pages, visitors to the blog have been reporting that some posts have missing images.  I have been through the entire blog and have identified all of the posts with missing images (see below).  The posts are old, all posted before the migration, but their content remains valid (albeit useless in the most part with the images missing).
NOTE:  I have previously been in contact with NI who have found the missing images for some posts but a definitive list of all posts with missing images was never available.
It would be a big help to me and The Daily CLAD visitors if the images could be found (links to their new locations updated).
Regards
Steve Brown
  1. http://forums.ni.com/t5/The-Daily-CLAD/Numeric-Array-Operations-2/ba-p/3479438
  2. http://forums.ni.com/t5/The-Daily-CLAD/BIT-Shifting-2/ba-p/3480061
  3. http://forums.ni.com/t5/The-Daily-CLAD/Build-Array-WHILE-Loop-2/ba-p/3481835
  4. http://forums.ni.com/t5/The-Daily-CLAD/Shift-Registers-and-Auto-Indexing-2/ba-p/3482567
  5. http://forums.ni.com/t5/The-Daily-CLAD/FOR-Loop-Count-N-Terminal-2/ba-p/3486480
  6. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-Strikes-Back/ba-p/3486812
  7. http://forums.ni.com/t5/The-Daily-CLAD/Mechanical-Action-of-Booleans-2-of-3/ba-p/3488872
  8. http://forums.ni.com/t5/The-Daily-CLAD/Mechanical-Action-of-Booleans-3-of-3/ba-p/3488916
  9. http://forums.ni.com/t5/The-Daily-CLAD/Building-strings-with-loops-Concatenate-Strings/ba-p/3474215
  10. http://forums.ni.com/t5/The-Daily-CLAD/Nested-For-Loop-Operation/ba-p/3474383
  11. http://forums.ni.com/t5/The-Daily-CLAD/Nested-For-loops-and-Waveform-Charts/ba-p/3474416
  12. http://forums.ni.com/t5/The-Daily-CLAD/Event-Structures-Boolean-Controls/ba-p/3474667
  13. http://forums.ni.com/t5/The-Daily-CLAD/Event-Structures-Boolean-Controls-2/ba-p/3474742
  14. http://forums.ni.com/t5/The-Daily-CLAD/Case-Structure-output-tunnels/ba-p/3474191
  15. http://forums.ni.com/t5/The-Daily-CLAD/Block-Diagram-Toolbar-2/ba-p/3475972
  16. http://forums.ni.com/t5/The-Daily-CLAD/Data-Types-Unsigned-8-BIT-Numeric/ba-p/3473992
  17. http://forums.ni.com/t5/The-Daily-CLAD/Building-strings-with-loops-and-Concatenate-Strings/ba-p/3474...
  18. http://forums.ni.com/t5/The-Daily-CLAD/Block-Diagram-Toolbar-3/ba-p/3476031
  19. http://forums.ni.com/t5/The-Daily-CLAD/Event-Structures-and-Val-Sgnl/ba-p/3476263
  20. http://forums.ni.com/t5/The-Daily-CLAD/The-ArrElem-Property/ba-p/3476302
  21. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Graph-Series-1-of-5/ba-p/3477924
  22. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Graph-Series-2-of-5/ba-p/3477985
  23. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Graph-Series-3-of-5/ba-p/3478046
  24. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Graph-Series-4-of-5/ba-p/3478144
  25. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Graph-Series-5-of-5/ba-p/3478187
  26. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Chart-Series-2-of-5/ba-p/3478302
  27. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Chart-Series-3-of-5/ba-p/3478382
  28. http://forums.ni.com/t5/The-Daily-CLAD/Waveform-Chart-Series-5-of-5/ba-p/3478446
  29. http://forums.ni.com/t5/The-Daily-CLAD/Format-into-String-1/ba-p/3483039
  30. http://forums.ni.com/t5/The-Daily-CLAD/Format-into-String-2/ba-p/3483076
  31. http://forums.ni.com/t5/The-Daily-CLAD/Keyboard-Shortcuts-CTRL-Space-then-CTRL-D/ba-p/3483506
  32. http://forums.ni.com/t5/The-Daily-CLAD/Manipulating-Time-1/ba-p/3476193
  33. http://forums.ni.com/t5/The-Daily-CLAD/Block-Diagram-Controls-2/ba-p/3476819
  34. http://forums.ni.com/t5/The-Daily-CLAD/Block-Diagram-Controls-3/ba-p/3476828
  35. http://forums.ni.com/t5/The-Daily-CLAD/Error-Handler-2/ba-p/3477269
  36. http://forums.ni.com/t5/The-Daily-CLAD/Array-Operations-2/ba-p/3478015
  37. http://forums.ni.com/t5/The-Daily-CLAD/Using-Concatenate-Strings-to-Build-Strings/ba-p/3474172
  38. http://forums.ni.com/t5/The-Daily-CLAD/While-Loops-2-Conditional-Terminal-Auto-Indexing/ba-p/3473908
  39. http://forums.ni.com/t5/The-Daily-CLAD/While-Loops-1-Conditional-Terminal-Iteration-Terminal/ba-p/34...
  40. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-8/ba-p/3473927
  41. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-7/ba-p/3473812
  42. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-6/ba-p/3473791
  43. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-5/ba-p/3473766
  44. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-3/ba-p/3473708
  45. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-4/ba-p/3473774
  46. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-3/ba-p/3473708
  47. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-2/ba-p/3473722
  48. http://forums.ni.com/t5/The-Daily-CLAD/The-Dataflow-Paradigm-1/ba-p/3473665
  49. http://forums.ni.com/t5/The-Daily-CLAD/For-loops-Shift-Registers-and-Auto-Indexing-2/ba-p/3473589
  50. http://forums.ni.com/t5/The-Daily-CLAD/For-loops-MIND-BENDER/ba-p/3473572
  51. http://forums.ni.com/t5/The-Daily-CLAD/For-loop-iteration-control-6/ba-p/3473603
  52. http://forums.ni.com/t5/The-Daily-CLAD/For-loops-Shift-Registers-and-Auto-Indexing/ba-p/3473552
  53. http://forums.ni.com/t5/The-Daily-CLAD/For-loops-and-Stacked-Shift-Registers/ba-p/3473519
  54. http://forums.ni.com/t5/The-Daily-CLAD/For-loops-and-Shift-Registers/ba-p/3473475
  55. http://forums.ni.com/t5/The-Daily-CLAD/For-loop-iteration-control-5/ba-p/3473488
  56. http://forums.ni.com/t5/The-Daily-CLAD/For-loop-iteration-control-4/ba-p/3473385
  57. http://forums.ni.com/t5/The-Daily-CLAD/For-loop-iteration-control-3/ba-p/3473448
Message 1 of 10
(3,994 Views)
Hello SercoSteveB,
Thank you for pointing this out to us. We will be working on this and consider we will have this ready at the end of next week.
We will update you as soon as we have completed this.
Best Regards,
Karina Barles
NI Community Support
Message 2 of 10
(3,961 Views)
Hi Karina
That's awesome, thanks.
Steve
Message 3 of 10
(3,941 Views)
Hello SercoSteveB,
We are still working on restoring the images, unfortunately as stated before, we will not be able to accomplish this in a week. We will keep on working on this and update you as soon as we have finalized.
Karina Barles
Message 4 of 10
(3,875 Views)
Hi Karina
Steve
Message 5 of 10
(3,854 Views)
Hi SercoSteveB,
We apologize for the delay. I have started working on updating the images for you. I will post again once I have completed the updates for you.
Best Regards,
Kristi Martinez
Best Regards,
Kristi Martinez
Message 6 of 10
(3,778 Views)
Hi SercoSteveB,
I have updated all the images except for 4. I will need to investigate a little further on those images. I will give you another update on Monday.
Best Regards,
Kristi Martinez
Best Regards,
Kristi Martinez
Message 7 of 10
(3,771 Views)
Accepted by topic author SercoSteveB
Hi SercoSteveB,
I have replaced all the broken images and corrected the images you mentioned were incorrect.
We appreciate your patience on resolving this issue.
Best Regards,
Kristi Martinez
Best Regards,
Kristi Martinez
Message 9 of 10
(3,731 Views)
Hi Karina and Kristi
All fixed that's awesome, thank you both for your time on this matter.
Regards
Steve
Message 10 of 10
(3,718 Views)
