11-09-2015 11:22 AM
For a few days, I notied the following behavior, which is new.
Why does it kick me out after I have already looked at some stuff that clearly require a login? There seems like a race condition oor something.
I would prefer if it would not log me out randomly. Thanks.
Solved! Go to Solution.
11-09-2015 11:43 AM - edited 11-09-2015 11:49 AM
Hi Christian,
We haven't made any changes on our side recently. There was a Lithium update early Friday morning, but the release notes mentioned no feature / setting change related this login. Has this issue been occurring since before Friday?
Edit: I do want to mention that there has always has been an inactivity time period in which you will be logged out for security purposes. I just wanted to clarify this as it's always been in place, but this report sounds as if there is a new issue here.
I have a few questions about your workflow:
1. Are you leaving your web browser open over the night?
2. When you start to browse the next morning, have you refreshed the page, or do you just start where you left over the night before -- assuming you leave the browser open?
3. Are you still logged in to ni.com -- do you see "Hello Christian" at the top right of the page? Or are you logged out of both the forums and NI.com?
If anyone else is experiencing this, please let us know.
11-09-2015 12:04 PM
Yes, I leave the browser open. Typically the first thing is to click on my name and then on the post history and I see a few bold threads. The one's with new activity. After clicking and inspecting the new threads (some even in private forums where I am definitely need to be logged in), I click again on my name and suddenly all threads are bold.
I the past, I was either logged out from the beginning or I was still logged in for good. Now we are somewhere in-between, it seems.
I'll try to inspect it more closely tomorrow once more. My routine is always the same and something has definitely changed.
11-09-2015 12:49 PM
I'll attempt to reproduce it overnight as well. It's certainly possible something happened in the latest release and we're not aware of it (like this floated topics column bug).
11-09-2015 01:42 PM
I noticed this as well. There have been times in the past where a logout interval would occur, but I think it has been a long since I had seen an automatic logout. That is until the last few days.
11-09-2015 02:12 PM - edited 11-09-2015 02:12 PM
When you're logged out, do you see any error messages?
When this happens again, noting the time stamp may be beneficial as well.
11-09-2015 02:16 PM
No error message. Just all threads bold.
Could it be that the cookie only resets on the forum homepage and not on other forum pages?
11-09-2015 06:06 PM
I have also seen behavior as Christian described.
My browser has an addon which automatically refreshes a page periodically.
I think when I have seen this behavior I had turned off the auto refresh but had not logged out. I do not recall specifically the sequence of actions but typically it will be sitting on the LabVIEW page. I often click on the Discussion Forums link to check a few other Boards, like this one, before going through all the new posts on the LV page. I can see one unread post. Then when I hit the Back command I find myself logged out.
This is farily recent - a few days or maybe a week.
Lynn
Safari on OS X
11-09-2015 10:19 PM
Just happened to me again. I was browsing the forum for at least 30 minutes when I suddenly found myself logged out.
Seemed completely random.
11-10-2015 01:53 AM
I haven't seen this recently, but I do remember a similar situation from a couple of years ago, when something was changed about the login. There was a discussion and the first post about this issue is here - http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/New-Login-Page-Authentication-Method/m-p/23...
I haven't looked through the whole discussion now, but skimming it I see that it was something about which link was used to log in and I see that I said I went back to the old link at some point. I don't know if I'm using the old one or new one now, but the bookmark I have now is
and I see that it has some comments on it which were probably left from when I was playing with it.
