Hello;
To be more accurate on my suggestions, I would need to know how fast the acquisition will run.
If the speed is not a concern, you can take a look at our Field Point modules, that are designed for industrial plant floors, and can handle a pretty wide temperature range. Also, you can look at the Field Point 2000 that is a stand alone controller that can be used together with the DAQ modules.
If speed is a concern, I would recomend you to take a look at the PXI modules.
Hope this helps.
Filipe
